- Enable multicast on the boundary nodes.
Configure Multicast Virtual Private Network (MVPN) on the boundary nodes, for layer 3 VSN.
Perform this procedure to configure Multi-area SPB IPv4 static I-SID routed multicast redistribution on the switch.
Routed multicast redistribution is available for IPv4 only.
Multi-area SPB boundary nodes can redistribute static data I-SIDs, and the static data I-SID multicast redistribution policy takes precedence over the Layer 2 multicast redistribution.
Multi-area SPB boundary nodes with remote IS-IS enabled do not support IP SPB Multicast Policy .
Configuring Multi-area SPB IPv4 static I-SID list to redistribute for remote to home direction:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis Switch:1(config-isis)#multi-area ip redistribute static-isid-routed-multicast remote-to-home isid-list list2 WARNING: L3 static i-sid routed multicast will not be inter-area redistributed until apply command is issued after enable command. Switch:1(config-isis)#multi-area ip redistribute static-isid-routed-multicast [home-toremote | remote-to-home] enable Switch:1(config-isis)#show isis multi-area ip redistribute static-isid-routed-multicast remote-to-home ====================================================================================================== MULTI-AREA IP REDISTRIBUTE STATIC ISID ROUTED MULTICAST - ALL VRF ====================================================================================================== DIRECTION ENABLE ISID LIST ------------------------------------------------------------------------------------------------------ remote-to-home TRUE list2 Switch:1(config-isis)#isis multi-area ip apply redistribute static-isid-routed-multicast
The following table defines parameters for the multi-area ip redistribute static-isid-routed-multicast command.
Variable |
Value |
enable |
Enables Multi-area SPB IPv4 static I-SID routed multicast redistribution. |
home-to-remote |
Specifies the IPv4 static I-SID routed multicast redistribution configuration for home to remote direction. |
isid-listWORD<1-32> |
Specifies the name of the I-SID list. |
remote-to-home |
Specifies the IPv4 static I-SID routed multicast redistribution configuration for remote to home direction. |
